Hazard Lights/Blinkers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2011, 10:21 PM
eandabailey's Avatar
My blinkers started going crazy about a year ago, and I'm getting sick of it. I have a 2000 Pontiac Grand Am, and the only way to make them work when they are acting up is to click the hazard lights on/off. Any ideas on how to fix this? Thanks
Old 03-18-2011, 06:42 PM
ROJ0's Avatar
It's ok, I got tools!
Have you checked the relay switch?
Old 03-18-2011, 06:52 PM
He said yes he checked the relay switch and that's not it...?
Old 03-19-2011, 04:18 AM
EOD Guy's Avatar
This your car or are you helping a friend?
Old 03-19-2011, 10:02 AM
My car. My husband is the mechanic. lol
Old 03-19-2011, 11:35 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
If I assume that the hazard flashers work OK I'm going with the hazard switch is bad.
However, if hazard flashers also act up that indicates a bad flasher module.
The system uses a common flasher for the turn signals and the hazard flashers.
When the turn signals are in use the circuit goes through the hazard switch. If the internal switch contacts are not making good contact the turn signals won't work properly.
vicrod
Old 03-19-2011, 12:55 PM
Thanks! My hazard lights also act up, so I will definately let him know. Thanks for the tip! Really appreciate it!
blinkers and brake lights krazeyone Electrical 6 06-22-2010 01:14 PM
wiring blinkers/brake lights pcoghlan Electrical 7 03-10-2007 09:47 PM
Wacko Hazard lights montea Electrical 5 12-30-2004 08:08 PM
Brighter tail lights and blinkers MARKDEB Electrical 15 12-10-2003 04:01 PM
the Pre-Hazard era WayOutCat Electrical 3 08-09-2002 08:11 AM
