Make sure you have a dry air in the hose when spraying and a good filter. Some high solids clear can actually trap moisture and air when being applied (very thick clear). Is the clear drying to fast? With the amount of orange peel, appears it may be drying too fast and the clear is not laying down flat. I have seen this with some Sherwin and PPG. I now use Wanda paint and I have superior results - plus I lay much more clear than most people do on a car because I am burying artwork. Make sure your flash times are correct - make sure the base is dry. Make sure your air pressure is high enough to atomize the clear.
