Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hd 3500 slave cylinder removal
Old 09-26-2006, 03:18 PM
nitro_baller4692's Avatar
nitro_baller4692 nitro_baller4692 is offline
floppers forever
i have used two pocket screwdrivers,push them in on both sides of the line and the line will come out there is a clip in there that you have to get past so make sure not to screw that up.if you can get the screwdriver to hold the clip to one side the take another to work it around the clip it will come out .puting them in is simpal they just push in.
good luck
