-   -   hd 3500 slave cylinder removal (http://www.hotrodders.com/forum/hd-3500-slave-cylinder-removal-99030.html)
propaniac 09-26-2006 02:21 PM
I am currently in the process of removing the trans from one of my work trucks and am having trouble disconnecting the line from the slave cylinder. It has what looks like a quick disconnect but I am having no luck with it and was hoping that someone hear has worked on one. I can disconnect it from the master but I was hoping there was an easier way.
I know its not a hot rod but it does have an 8.1l engine in it.
Thanks
John
nitro_baller4692 09-26-2006 03:18 PM
i have used two pocket screwdrivers,push them in on both sides of the line and the line will come out there is a clip in there that you have to get past so make sure not to screw that up.if you can get the screwdriver to hold the clip to one side the take another to work it around the clip it will come out :sweat: .puting them in is simpal they just push in.
good luck
DrChop 09-26-2006 03:40 PM
Fuel/AC line removal tool....
Looks like a piece of split tubing, fits over the line and you push it into the fitting, then pull the line out of the fitting. They come as a set, under $10 any auto parts store...
Doc
