hd 3500 slave cylinder removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 01:21 PM
Last journal entry: More propane stuff
I am currently in the process of removing the trans from one of my work trucks and am having trouble disconnecting the line from the slave cylinder. It has what looks like a quick disconnect but I am having no luck with it and was hoping that someone hear has worked on one. I can disconnect it from the master but I was hoping there was an easier way.
I know its not a hot rod but it does have an 8.1l engine in it.
Thanks
John
Old 09-26-2006, 02:18 PM
nitro_baller4692's Avatar
floppers forever
i have used two pocket screwdrivers,push them in on both sides of the line and the line will come out there is a clip in there that you have to get past so make sure not to screw that up.if you can get the screwdriver to hold the clip to one side the take another to work it around the clip it will come out .puting them in is simpal they just push in.
good luck
Old 09-26-2006, 02:40 PM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Fuel/AC line removal tool....
Looks like a piece of split tubing, fits over the line and you push it into the fitting, then pull the line out of the fitting. They come as a set, under $10 any auto parts store...
Doc
clutch hydraulic slave cylinder automan431 Transmission - Rearend 2 12-31-2005 10:25 PM
slave cylinder Super Chevy Transmission - Rearend 6 01-04-2004 09:43 PM
How to bleed clutch slave cylinder? shockers69 Transmission - Rearend 5 12-18-2003 08:47 PM
Ignition Cylinder Removal brettc Interior 1 09-14-2003 09:50 PM
clutch slave cylinder mount wally Transmission - Rearend 1 03-04-2002 09:20 AM
