Head ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2003, 08:56 PM
onehotchev's Avatar
Post Head ?
What are swirl port heads
and how do you know if they are swirl port?
Winning isn't everything but loosing sucks
So drive it like you stole it
Old 01-25-2003, 01:51 AM
banned
Post
I believe that these are heads that have had the ports polished and a swirl pattern etched in (to keep enough turbulance in the air to keep the maximum amount of fuel in vapour state and prevent it from condensing)
How do you tell... I'd like to know too chuck will probably know
Old 01-25-2003, 05:18 AM
BOBCRMAN@aol.com's Avatar
Post
the swirl port head on a small block chevy has a tall narrow port with a "finger" that protrudes into the port just above the intake valve. you can't see it with the valve in the head. the casting nos. for a 350 will be 191 or 193. these are std heads from about 1989, they are VERY crack prone like all of GM's later castings.
Old 01-25-2003, 05:57 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Ditto with Bob, good for a shop door stop.
Old 01-25-2003, 06:15 AM
Post
I read in GM paperwork somewhere(I'll see if I can find it again), that the pre Vortec truck heads with the "High Swirl" intake port, reduced flow by 18* to increase gas mileage by 13*. Dan
Old 01-25-2003, 11:47 AM
banned
Post
okay then what I read somewhere was wrong
Old 01-25-2003, 01:33 PM
onehotchev's Avatar
Post
The Casting Numbers are 14102188
and a date B-02-1
so is that February 2 1991
thanks for info
