Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head assembly Q, more like dis-assembly
Old 11-26-2007, 05:28 PM
bullheimer's Avatar
bullheimer bullheimer is offline
NEVER use credit cards!
okay so i took the heads to a guy to check them out and he removed all 8 valves from a head and throws all the parts into a box. now i have no way of knowing which valve came out of which hole, nor which ball went with which rocker arm. or which valve lock went to which valve.
i just took another set of heads apart one valve at a time, so that it would go back the way it was. (first time i ever did it myself, cause of the above)
does this matter at all? should i care? can i just put it all back together? and what about emmie lou?
