Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head assembly Q, more like dis-assembly
Old 11-26-2007, 09:02 PM
lust4speed's Avatar
lust4speed lust4speed is offline
I agree that only valves and seats are really critical. Treat it as a puzzle and see how good you are matching up parts. First place to start is to look for patterns between the exhaust and intake valve heads. One or two cylinders will probably have more carbon and those valves should also be darker. You might even have some patterns across both valves that would line them up. If this doesn't match them all up, then you are stuck fitting them in their holes and checking how well they seal up.
