Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head assembly Q, more like dis-assembly
Old 11-27-2007, 04:48 AM
k-star k-star is offline
Last journal entry: PICTURE TEST
parts
If the valves and seats are good enough to use without re-machining them then it's not a problem. If they are bad enough that you can't swap holes then they need re-machined anyway..
I personally have never had any issues with swapping rockers/balls/pushrods etc.. Again if it's worn enough not to mix and match you shouldn't be using it anyway.
Keith
