Which head is best? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2009, 03:47 PM
Which head is best?
G'day. Because of the outrageous prices of aftermarket heads over here, I am limited to rebuilding a set of factory chev heads. I have a pair or 882's and a pair of 624's. Which is the better of the two and how do they compare.
Thanks
Old 01-13-2009, 04:18 PM
GMC boogie's Avatar
of the two.....882's. Are they the heavy castings?
Old 01-13-2009, 04:20 PM
How do you pick the heavy castings?
Old 01-13-2009, 04:56 PM
GMC boogie's Avatar
If the outer edge of the exhaust side is straight from one end to the other,it's a heavy casting.
If it is scalloped out,it is a very crack prone late style light casting.
The 624 will be a light casting.
Hope I made sense...a picture would explain it well.
Old 01-13-2009, 05:11 PM
GMC boogie's Avatar
Here is a set of heavy 882 castings
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Notice the straight edge from end to end along the exhaust side,except for the two small cut outs.
Old 01-13-2009, 05:22 PM
GMC boogie's Avatar
Here is an example of a late style light weight casting
Notice the large scalloped out areas.
Old 01-13-2009, 05:41 PM
Thanks for the info. The 882's i have are heavy castings. Will they fit an early 70's 350 block.
Old 01-13-2009, 06:09 PM
GMC boogie's Avatar
Yes,they will fit.
VW Jetta Cylinder Head Chevy21 Engine 2 02-13-2008 09:04 AM
SBC HEAD QUESTION: Need Help Picking A Head Mustangsaly Engine 10 11-30-2007 01:48 PM
Head Gasket Selection!!! sexypizzaman Engine 2 09-21-2007 09:37 AM
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
which head to use? sune Engine 8 03-07-2004 01:44 PM
