Head bolt ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 09:36 AM
Head bolt ?
Putting my SBC together and realize that I may or may not have made a mistake. Looking for input to decide if I should redo. Anyways, bolted my vortec EQ heads to the block using a felpro composition gasket and the GM products head bolts (have sealant already one them). For some crazy reason, perhaps it was a long day and I wasn't thinking, I dipped the threads in oil before inserting them into their holes. In my mind I was thinking this would provide a better torque reading then I realized they already have sealant on them. Did I mess up the sealant on the threads? Also, I think that oil most likely dripped and spread between the heads and the gasket or block and gasket.
Is this okay or should I remove the heads and get new gaskets, bolts and redo? Thanks!
Old 06-15-2013, 05:10 PM
BOBCRMAN@aol.com's Avatar
You will be alright. Many builders oil the sealed threads. Also oil the bolt under the head for better torque reading.
Old 06-15-2013, 10:25 PM
Good to know. That will keep me from shelling out another $100. For future reference is it more appropriate to just put some oil under the bolt head and leave the threaded portion alone? Again, I hope that no oil getting between the head and gasket will create an issue.
Old 06-16-2013, 12:43 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Oil is OK, but there are better options. ARP makes fastener torque lube as well as some other companies. Torque lube gives a much more consistent and accurate torque reading than plain oil.
Head bolt retorque? Richiehd Engine 1 07-01-2012 03:39 PM
Head Bolt Question Gokussj5okazu Engine 9 03-24-2010 03:45 PM
Stripped head bolt. Toddclary Engine 4 04-18-2009 10:31 PM
Cylinder head bolt sexypizzaman Engine 4 01-10-2008 05:40 PM
Head bolt installation worcoguy Engine 5 01-12-2007 05:20 AM
