Head Bolt Goob - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2007, 07:47 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Head Bolt Goob
I read somewhere to use Permatex 2 on head bolt threads on the SBC. Any other recommendations??
Old 01-21-2007, 08:11 AM
71C10's Avatar
U.S. Army Retired
I've used it many times with no problems. I prefer the ARP Teflon stuff now:
http://www.sdpc2000.com/catalog/2605...ead-Sealer.htm
Old 01-21-2007, 08:20 AM
Permatex High Performance Thread Sealant.
It's white stuff in a white tube. I like to take a small screwdriver and put a little bit of the sealant into the bolt holes along with the stuff that is on the bolt.
Also a drop of oil under the head of the bolts.
After the heads are all torqued up and sitting for a few minutes following the torque sequence one at a time I'll back the bolts off about a 1/8 of a turn and retorque them.
A Felpro gasket engineer told me about that retorque deal years ago and it has worked out great. Put a small mark on the bolts with a silver Sharpie before you do the retorque thing and you'll see that they change a little bit.
I don't retorque them after the engine has been run and cooled.
That is more than you asked for but thats a great tip that was given to me so I'll pass it on.
Have fun,Smokey
Old 01-21-2007, 10:32 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Anybody use RTV silicone? I found some on the head bolts I took out of my 350.
Head Bolt Torque (ford-y-block) W.THERIAULT Engine 1 01-15-2007 04:11 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
