head bolt opps - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2003, 04:32 PM
Post head bolt opps
how or what is the best way to get a broke head bolt out
Old 02-24-2003, 04:39 PM
awsum34's Avatar
Post
drill them out and use a easyout. or redrill the hole and retap the hole
Old 02-24-2003, 04:42 PM
Post
thanks
Old 02-24-2003, 06:39 PM
4 Jaw Chuck's Avatar
Post
Mig weld a nut (non-plated) to the exposed portion building up using a spot weld technique if needed, turn out just like that usually unless it was bottomed...hard.
Outlawed tunes from outlawed pipes
Old 02-24-2003, 07:37 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
You can try to use a drill bit slightly smaller than the bolt shank , then peel the remianing threads out. You need to be precise here.
