Head Bolt Torque (ford-y-block)
Again I Need Some Help With My 312 Ford Engine. I Removed Both Heads Because I Had A Stuck Valve On One Of The Heads, While I Was There I Lapped In All The Valves & Put New Valve Seals In. Now Its Time To Install The Heads & I Looked Up The Head Bolt Torque One Book Tells Me The Torque Is 55ft.lbs. 2nd. Is 65 Ft. Lbs. & Last Torque Is 75ft. Lbs. Hot. Another Book Tells Me 1st. Torque Is 70ft. Lbs., 2nd Is 80ft.lbs. & Last Is 90ft. Lbs. Hot.could Someone Please Help Me Out, Before I Damage Something. Thanks For The Help Headache
re: Head Bolt Torque (ford-y-block)
Don't tighten those bolts too much, remember it's a Ford! Sorry, I just had to say it...
Here's another forum with the same question.. and a couple of answers. http://www.ford-trucks.com/forums/56...que-specs.html Good Luck |
| 400 sbc | Devin 427 | Engine | 19 | 06-08-2010 07:17 PM |
| Ford Big block 4 spd bellhousing | bigblocktorino | Transmission - Rearend | 3 | 10-05-2006 03:56 AM |
| Found broken intake bolt in head | Skipr | Engine | 4 | 08-06-2006 07:36 AM |
| Nooby need engine building help | hearseycakes | Hotrodding Basics | 12 | 12-05-2005 11:31 AM |
| Track Car Overheating, small block Ford | RAW | Engine | 15 | 12-16-2003 10:25 PM |
