head bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2010, 05:12 AM
head bolts
I have a 1988 f150 4.9 liter straight 6 can head bolts in this engine be reused.
Old 10-12-2010, 05:25 AM
Caballerokid's Avatar
I would just replace them with an ARP head stud kit.
Old 10-12-2010, 06:54 AM
BOBCRMAN@aol.com's Avatar
Much cheaper to re-use the original bolts. Which is common practice.
Old 10-12-2010, 04:01 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Yes. They are intended for re use . They are NOT torque to yield bolts.Look at them real good for signs of stretching and if they pass re use them.
Usually if they strech (not common on 4.9 ford) the shank area will have a spot that is skinnier than the rest of the bolt.
Old 10-12-2010, 04:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I re-use them no problem.
Cole
Reuse head bolts jmichaelre Engine 8 10-30-2009 03:17 PM
Stumped on leaking head bolts redride Engine 16 05-05-2009 02:20 PM
1949 flathead head bolts? northernhillbilly Engine 3 07-04-2006 06:33 PM
5.0 head bolts oldred Engine 4 12-18-2004 09:09 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
