Head bolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 09:42 AM
Post Head bolts?
i have a 79 350 i was wondering if i should use silicon on the threads of the bolts? Also do i put anything on the intake manifold gaskets? I heard you should put something around the water jackets is this true?
thanks
Old 11-05-2002, 11:06 AM
bullheimer's Avatar
NEVER use credit cards!
Post
i wouldnt put silicone anywhere inside the engine. i use it in place of the rubber pieces on the intake tho, and you do want to put some sealer just around the water holes. if you use the rubber pieces you need a dap of silicone on each end. you know the drill
Old 11-05-2002, 12:15 PM
slider in wa's Avatar
Slider in Wa.
Post
Bullheimer is right as usual!!!! The head bolts get "Anti seize" only. Do it!!! I agree with the bullheimer that if you use the rubber gasket(Front and rear) use a dab of sealant on the corners.I use them!!! Some guys say just use sealant. Not me, I`m simple minded enough to think they were made for a perpose. And the factory uses them, so shall i. I like to use a product called Indian head just to stick the gaskets in place.And as a sealant i preferr copper coat.Good luck.
Slider in Wa.
Old 11-05-2002, 04:14 PM
BOBCRMAN@aol.com's Avatar
Post
we use a teflon paste on all small block head bolts it acts as a sealer and an antiseize also gives better torque readings.a small amount of silicone around the intake crossover ports.
Old 11-05-2002, 06:26 PM
Post
ARP produces a thread sealer and has a different torque value if used. ARP head bolts also have different torque values when using either motor oil or moly lube. The thread sealer would be good to use when the bolts extend into a water jacket. If a hole has a bottom make sure there isn't any thread sealer or lube on the tip of the bolt, this could cause a hydraulic lok and bust a block around the bolt.
Old 11-11-2002, 04:54 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Thumbs up
I agree with BOBCRMAN ,use the teflon paste and you wont have any problems.
Luv the smell of NITRO in the morning.
Old 11-11-2002, 05:13 PM
roys63's Avatar
Thumbs up
Yes! Teflon Paste you must seal the bolts on SBC and BBC they run into the water jacket.
Old 11-11-2002, 08:11 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post
I always use a liquid teflon...about any parts store carries it, comes in a little white squeeze tube. There is enough in there to do probably 2 or 3 motors worth. At only $3.00 a tube, you can't go wrong.
Later,
WEIMER
