-   -   head bolts or head studs? head gaskets? (http://www.hotrodders.com/forum/head-bolts-head-studs-head-gaskets-141324.html)
thefloyd1973 07-02-2008 08:47 AM
i have to take apart my 383 stroker here shortly and i know the bottom end has all eagle rotating assy and is held together with arp studs. the compression is 9.9:1 and i have rhs pro torquer heads. is there any advantages to using head studs compaired to head bolts? would it be worth my money and time to get them instead of bolts? comments would be great? and for a 350 block thats bored .40 over whats the best head gasket possible to buy thats around .41 thick?
Stroke 07-02-2008 09:02 AM
Studs have their pros (better clamping, less block thread wear) as well as cons (seepage and possible interference, as in tight fit to the head). If you don't need them why bother? On the other hand, studs are the way to go, IMO. As for head gaskets, you're going to get as many replies as there are head gasket mfrs. Just don't cheap out when you buy them.
thefloyd1973 07-02-2008 09:16 AM
seepage? meaning compression leaks out? and they are the way to go?
SSedan64 07-02-2008 09:31 AM
Seepage?? If it's a street car don't use head studs. Race, I say go for it. On a street car when removing the heads you may run into brake booster & A/C interference etc. Studs do offer the best clamping method. It just depends on if they're applicable. I don't think they're really needed unles you're using plenty of Nitrous or Boost.
Stroke 07-02-2008 09:34 AM
Seep, leak, you get the idea.
Yes No Yes. Sometimes, you will experience seepage of coolant in and around the studs. Not always, sometimes. Sometimes a lot, sometimes a little, sometimes none. It's just something to look out for if using. JMO
thefloyd1973 07-02-2008 10:04 AM
ok, i am taking the motor out. so i guess the brake booster wouldnt be a problem. i just wanna do it the right way and not think back to damn i should have done this or that. any thoughts?
Stroke 07-02-2008 10:28 AM
any thoughts?
HEAD STUDS vs. BOLTS...A TECHNICAL DISCUSSION
Factory head bolts as compared to ARP studs
T-bucket23 07-02-2008 10:30 AM
I used studs and I wouldnt do it again on a non race engine. They are a pain in the butt to get to seal. I used good (arp) studs and there recomended sealer and still had a few leakers. I ended up using a permetex product and finally got them to seal. I dont have the space issues in my tbucket but in a car with fenders I guess they could present some space issues as well.
Chet
jimfulco 07-04-2008 07:51 AM
And if you ever want to take a head off without pulling the engine, you may be SOL.
sam-missle 07-04-2008 09:25 AM
there should not be any issue with removing heads with studs while in the vehicle. the studs will have a female allen head to them, use permatex #2 non hardning on the treads(block side) when you install the studs. remove the studs before the head.
sam-missle
