Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head bolts or head studs? head gaskets?
Old 07-02-2008, 09:34 AM
Stroke Stroke is offline
Seep, leak, you get the idea.
seepage? meaning compression leaks out? and they are the way to go?
Yes No Yes. Sometimes, you will experience seepage of coolant in and around the studs. Not always, sometimes. Sometimes a lot, sometimes a little, sometimes none. It's just something to look out for if using. JMO
