Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head bolts or head studs? head gaskets?
Old 07-04-2008, 09:25 AM
sam-missle sam-missle is offline
there should not be any issue with removing heads with studs while in the vehicle. the studs will have a female allen head to them, use permatex #2 non hardning on the treads(block side) when you install the studs. remove the studs before the head.
sam-missle
