Head Bolts ?? Reuse ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2008, 01:28 PM
Can you reuse headbolts that were already torqued on the heads or do you have to buy new ones ?
Old 09-15-2008, 01:36 PM
It depends on the engine. If the bolts are torque to yeild, then no the bolts are over stressed at this point. On older engines SBF & SBC the bolts can be reused if in good condition. Depending on the engine build you may want to consider using ARP studs. With high hp don't take any chances on using old bolts. With a standard rebuild reusing head bolts should not be a problem. I must say that many builders will not take any chances and always use new bolts. Tom F.
Old 09-15-2008, 01:37 PM
It depends. I believe that it was sometime in the late 80's (??) that most headbolts went to a "torque to yield" design which actually allows the bolt to stretch at a specific amount of torque. These need to be discarded and replaced after each use, bolts made before the switch can be and have been used over and over as they are hardened, made for the job and have no such soft spot. But I believe that youl find that the common practice nowadays is to replace them, especially for a performance application.
Old 09-15-2008, 01:52 PM
Thanks i think im going to go with the ARP Studs they work the same way right same torque sequence
Old 09-15-2008, 02:22 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Use permatex non hardning #2 on the block side of the studs.
Rich
http://www.alamomotorsports.com/arp/arp_headbolts.html
http://www.dieselwarden.net/ford/project18.html
Old 09-15-2008, 03:50 PM
327NUT's Avatar
My own opinion.....but I wouldnt use studs unless I was building a very hipo blown or nitrous engine, just not needed. Plus they cost more than regular bolts and if you're engine sits in any normal vehicle engine bay you'll play hell getting the heads off over the studs (if you ever have to). A good set of ARP bolts will work just fine....in most applications.
Old 09-15-2008, 04:54 PM
if you use the #2 non harding as mentioned above the studs will come out with no problem, so if you need to pull the heads, just pull the studs first.
sam-missle
Old 09-15-2008, 05:21 PM
The problem you often get into with studs used on engines in stock bodied cars is that very often you can't get the heads off with the engine installed as there is not sufficient space to raise the head to clear the studs.
ARP bolts work very well and get around this problem.
Bogie
Old 09-15-2008, 09:35 PM
Jmark's Avatar
Yep, very good advice!
Old 09-15-2008, 09:46 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Bogie
The last set of ARP studs I bought had a small hex in them to allow them to be screwed in and out with an allen wrench. That would allow you to remove the studs if pulling the heads in the vehicle was needed, although it would still be a pain in the butt.
Old 09-15-2008, 09:49 PM
DoubleVision's Avatar
If you decide to go the stud route, or even new bolt route, make sure you retorque them, if not it`s asking for a blown head gasket. Since the bolt or stud is not "seasoned" in, it`s always a good idea and safe practice to go back and retorque. I`d rather go through the pain in the *** procedure to retorque rather than remove the head.
Old 09-15-2008, 10:25 PM
327NUT's Avatar
Well I reckon Oldbogie didn't read #6.....LOL
Stretch Head Bolts For Small Chevy? NAIRB Engine 2 05-26-2006 09:23 PM
ARP head bolts oldred Engine 4 04-01-2005 11:32 AM
5.0 head bolts oldred Engine 4 12-18-2004 10:09 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 05:50 PM
SBC head bolts fred56 Engine 2 03-27-2003 11:44 AM
