Head casting identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 01:21 PM
I have chevy heads casting # 462624 & block casting #3970010 can you tell me the year.
Old 04-12-2011, 01:30 PM
DoubleVision's Avatar
462624 350 76-87 1.94/1.50 2.02/1.60 76cc Crack prone
These heads are very light casted and crack prone. All SBC Heads and blocks have the date code casted on them. Here`s a example:
B 5 8 B - The Month B - February 5 - the date, 5th of february.
8 The year - 1978 or whatever years that casting was being cast.
You`ll find the date codes to your heads in the top side of the heads. The blocks date code is on the rear bell housing flange.
3970010 302/350 69-79 145-370 car & Truck 2 & 4-Bolt Most common
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 09:09 AM
gm head casting # my87Z Engine 4 03-30-2009 02:43 PM
head casting # shawtpop74 Hotrodders Site Suggestions and Help 1 03-29-2007 03:36 PM
Ford Axle Identification ( Casting Numbers ) Ozsuba Transmission - Rearend 1 01-01-2006 10:55 PM
Block Casting Identification bluesman123 Engine 2 05-04-2004 08:55 AM
