head casting number - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2007, 08:30 AM
head casting number
Can anybody tell me what this chevy head fits? The casting number is 882.thanks
Old 05-24-2007, 08:44 AM
DoubleVision's Avatar
These were common on both 350 and 400 engines from 1974 to 1980. There has been many disputes on them, some say there heavy casted, others argue there light casted and crack prone. Most of the ones I`ve seen were cracked. They had decent intake runners but large 76cc smog chambers. Not exactly a performance head. If the heads came off a 400, they will have steam holes inbetween the chambers.
Old 05-24-2007, 01:11 PM
malibu68's Avatar
A really good place for casting numbers is Mortec.com, they have block and head casting numbers and all the info you need.
its all about the links. good luck
Old 05-24-2007, 02:24 PM
nitro_baller4692's Avatar
floppers forever
heres a link with flow #'s
http://users.erols.com/srweiss/tablehdc.htm
Old 05-30-2007, 05:43 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
i have those heads on my 350 that i rebuilt and with what the machineshop did to them was great! im not sure what the flow and everything is but on the dyno with these heads they ran 375HP and 410 ft. lbs. of tourque i had them stage 2 port and polished and they are 2.02/1.50 not 1.60 like most 202 heads have because they are originaly 1.94 heads but they were bored to 2.02 on the intake! the heads can be made into performance heads! but from the factory they do not flow good! and i will eventually change them over to a set of Aluminum heads but at the time i didnt have that much money!
Engine specs:
350 4bolt main bored .030 to 355cid
steal crank (3.48" stroke)
Sealed power flat top -5cc flat top
Speed pro piston rings
Stock rods with Milodon chromoly Rod bolts
all felpro gaskets
heads are chevy 882 heads with a stage 2 port job
Manley Stainless steel valves 2.02int. 1.50 ex.
Comp cams roller tip rocker arms 1.6 ratio int. 1.5 ratio ex.
z-28 valve springs
Comp cams XE268 camshaft
Moroso Chrome oil pan
Moroso Chrome valve covers
comp cams 84000 series lifters, which are very strong and expencive
Holly 650 DP
K&N airfilter
over all about a $3000 build!
block VIN and casting number sweetcamaro69 Engine 2 06-05-2006 09:12 PM
block VIN and casting number sweetcamaro69 Hotrodding Basics 2 06-05-2006 09:09 PM
Cylinder Head Casting Numbers chianesi Engine 0 06-01-2004 07:30 PM
GM 3-series open carrier casting number ken47 Transmission - Rearend 0 11-30-2003 10:00 AM
missing casting number? 78importbeater Engine 5 07-22-2003 09:45 AM
