Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head choice???
Thread: head choice???
Old 05-09-2009, 11:18 AM
firestone's Avatar
firestone firestone is offline
http://teamrfc.gospelcom.net
how much can you spend on a set of heads? From what I have seen, an un ported set of the patriot type heads will get you ~600 hp with your current setup. In order to get over 700 you will need some CNC, or hand ported Brodix/AFR/Dart... heads. Another idea that will get you in the ~600 range would be the Dart iron eagle 308cc heads. In order to know for shure, we need to know the cam specs, and compression at a minimum.
this may give you some info:
http://www.chevelles.com/forums/show...light=pro+comp
Here are some dyno results
http://www.chevelles.com/forums/show...t=patriot+dyno
This one is a little more like yours:
Adam
