Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head choice???
Thread: head choice???
Old 05-09-2009, 10:22 PM is offline
head q's
Thanks firestone for the patriot info. The bottom filler ad and dyno time said that with a little massaging and Some more cam 675 would be obtainable. I'm running 1000 cfm barry grant carb huge solid custom erson cam, more cubes and can spin 7000rpm. So I'm pretty confident on the numbers we're figuring. Also he said if it didn't make the numbers we agreed on he'd foot my bill and free engine time. I know he built a 496 with oval ports trick flow heads that made 697 I watched it and can hace the same trick flow heads but dont know know to much about the heads and wanted rec portss for the numbers. Any info on trick flow also would help and thanks again firestone info is great sounds like patriots make the numbers. No more pro comps ever here.,
