Head fastener recommenration - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 11:30 PM
Ive been throwing ideas around in my head for a while.
I know studs are more reliable but will bolts be sufficient.
My setup will be a 383 with approximately 11:1 cam has .525/.540 lift and 242/252 dur @.050 would studs be a necessity with this kind of compression or would bolts be fine.
both options would be ARP.
Old 06-15-2007, 11:57 PM
DoubleVision's Avatar
The factory`s used bolts in engines with higher compression than that. But if it were me I would use studs. I would feel safer with studs than bolts.
Old 06-16-2007, 12:02 AM
I'm leaning towards the studs for a couple reasons, they save the threads in the block and aren't much more expensive than bolts 129 isn't a bad price for consistancy
Old 06-16-2007, 06:50 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I personally prefer bolts for a few reasons. The new generation of stuff from companies like ARP are overkill even at your pressures. Studs sometimes interfere with headers (which is a very small thing, but can be inconvenient making you grind on the flanges of your sexy ceramic coated headers.)
I also like the fact that when (notice I didn't say if ) you blow a gasket, drop a valve, yadda yadda, removing a head in a car with studs almost always means pulling the engine. Removing the head with bolts is easy as pie.
Old 06-16-2007, 07:49 PM
King of my Man-cave.
I think stock bolts, properly torqued, would work fine. If you do use aftermarket bolts or studs, they should be used when the block is torque plate bored and honed.
tom
Old 06-16-2007, 09:54 PM
Agree with the other member who said the factory used higher then 11:1 with factory bolts. If your machine work has already been done you should use whatever fastener was used with the torque plates.
Old 06-17-2007, 10:29 AM
thanks for the advice I think I will go with the ARP bolts then as my machine work hasn't been done yet.
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
'65 6 cyl. Mustang Head Gasket Problem 68Ranchero General Rodding Tech 6 04-27-2005 12:20 PM
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
which head to use? sune Engine 8 03-07-2004 01:44 PM
sb dodge cyl head identification/specs #73avenger Engine 0 02-15-2004 12:35 AM
