We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-05-2007, 05:17 PM
camaro freak camaro freak is offline
Head Gasket 101
Ok folks there is threads about a few different head gaskets on here but I don't see anyone talking about the head gaskets they use and why. Lets say you are building a 383 chevy with 10 to 1 compression. The heads and deck surfaces are within .003". What head gasket do you think is the best and why? What head gasket has never given you a problem and is there any thing special you do to the gasket when installing it?
Old 08-05-2007, 05:54 PM
Jmark's Avatar
Jmark Jmark is offline
I have always used Felpro blue, put on dry and never re-torqued and never had a problem.
Mark
Always on the look out for cheap Nike shoes!
Old 08-05-2007, 06:59 PM
ernkazern ernkazern is offline
Head Gasket 101
Same here, Fel Pro Blue, standard thickness, installed dry. Be sure both mating surfaces are perfectly smooth, clean, and dry. Chase and clean the threads in the block and the bolts if reusing old bolts. Lightly oil the bolt threads before installing them. Tighten the bolts in 3 steps using the manufacturers torque specs and order.
Old 08-05-2007, 07:31 PM
GMC boogie's Avatar
GMC boogie GMC boogie is offline
Just in case you need a third opinion....Im with Jmark and ernkazern. I have used the same gaskets installed the same way on many SBC builds and have never had a problem.
Old 08-05-2007, 10:54 PM
Jon's Avatar
Jon Jon is online now
Hotrodders.com Administrator
Jon's barnstar
Wiki editor
Wiki Edits: 6,687
I've just put together a wiki article on the subject of head gaskets: Head gasket. I got the idea from the title of this thread. This subject gets discussed a lot, so we might as well set up a centralized article on it.
Feel free to add to or edit the article. Just click the "edit" tab at the top of the page, or one of the "edit" links in a section. You can edit anonymously, without registering a wiki username, but if you register, your "Wiki Edits" count below your post count will increase as you edit.
We could also use some pics for the article. The various different kinds of head gaskets, a blown head gasket, and some pics of telltale blown head gasket signs: milkshake oil, foamy coolant, etc. If you have those pics, or can take them, click here to upload them to the wiki.
Here it is again: Head gasket.
Old 08-06-2007, 07:41 AM
tomthecomic tomthecomic is offline
felpro
felpro all the way. Spend the money
Old 08-06-2007, 08:07 AM
fitzwell fitzwell is offline
Victor-Reinz here. Light coating with K&W copper coat. let set-up abour 10 min & assemble. Before the flaming begins....I KNOW what the isntallation instructions say. Learned this procedure from a very talanted engine builder about 20 years ago, never had a problem.
Old 08-06-2007, 09:27 AM
oldbogie oldbogie is online now
For a street engine from stock to well hopped up GM gaskets are plenty fine and then some.
Bracket racing I use Fel Pro. Beyond that copper and O rings, but this is for really serious engines and is expensive overkill on the street.
I put gaskets down with a light oil or grease like petroleum jelly on both sides or with dry graphite (unless the gasket already uses a self lube coating, this allows the all the parts to move around smoothly while tightening things down so the material doesn't get pinched.
I always torque down in 5 or 6 sequences cycle the engine cold to hot to cold again and re-torque the bolts.
Always follow the manufacturers recommendations on thread condition. All threads are chased with a chaser not taps or dies, this is especially important on the bolts as they are rolled not cut threads and a die will change their quality.
Bogie
Old 08-06-2007, 09:32 AM
bigbadbowtie's Avatar
bigbadbowtie bigbadbowtie is offline
Bottle Fed
Felpro 1010 on my flat top 355 with small pills in the nitrous. Never an issue.
Old 08-06-2007, 09:39 AM
barnym17 barnym17 is offline
Fel-Pro, but the blue ones won't hold on anything much over a stock rebuild, got to step up a little.Stock Gm shims are great if the heads and block are properly machined.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Head Gasket 101"
Choosing correct Head Gasket - HELP! NovaHO Engine 4 05-30-2007 06:39 AM
is this the right head gasket for a 305 SBC? pcoghlan Engine 4 05-07-2006 05:02 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
