head gasket
I have a topend kit that I had on a 350 and just got a new short block. It recommends a felpro with a .039 and I am also looking at a .041. I know this is not much. Will the .041 lower my compresion. The new block has a 10.4 I would like to lower it a bit. Will the .041 gasket cause any problems? Also will my push rods need to be longer.
daaaaaaaaaaa
the pistons are round. no no they are flat with 4 valve forged. I dont know how far in the hole I do know it is not much. Wish I was more help. I am picking it up today and will ask
Tom, if you are getting it from an engine shop, ask them to put a dial indicator on a few cylinders and check how far down from the deck they are, then write all of them down. If this is just a private purchase, stop by a local machine shop and ask them to measure it for you. Make sure they measure from the side of piston that is parallel to the crank so any piston rock is eliminated from the equation.
chas |
thanks
I guess I will go with the .039. The motor guy did not know much. Makes me feel good about my purchase
Copper gaskets are available in several different thicknesses. .060 will help your compression problem. You might find something more suitable for your desired compression. Thicker head gaskets also necessitate thicker intake gaskets and longer pushrods. You will lose squish/quench, but that is the price for lowered compression by thicker gaskets. I would consider Singh grooves. |
| Head Gasket 101 | camaro freak | Engine | 9 | 08-06-2007 09:39 AM |
| Choosing correct Head Gasket - HELP! | NovaHO | Engine | 4 | 05-30-2007 06:39 AM |
| buy a used engine vs. replace head gasket? | andrewpruitt | Engine | 8 | 03-21-2005 05:52 PM |
| Cracked Head or Blown Gasket? | '71 rag top | Engine | 1 | 12-15-2004 10:08 PM |
| Head Gasket installation | '67Pony | Engine | 3 | 07-27-2003 11:33 AM |
