head gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2010, 08:46 AM
head gasket
i am installing a set of Pro Comp PC5213 CHEVY SBC 400 ULTRA HIGH PERFORMANCE STAINLESS MULTI-LAYER HEAD GASKETS Three layers of pure 304 stainless steel
Outer layers embossed and coated on both sides with Viton a state of the art flourelastomer rubber based material
but not shure what side should face up ,raised or concaved , i put raised up but had to knotch for oil stick always installed raised side up but hope this was rite and will work they were knotched for oil stick flipped this side down STEEL gaskets raised side up i alway thought
Old 04-18-2010, 09:11 AM
bondo's Avatar
Ayuh,... I would Think the notch would be a dead giveaway as to which way they go....
Old 04-18-2010, 10:56 PM
ericnova72's Avatar
More for Less Racer
The notch would be the giveaway but it really doesn't matter which way up or down, the sealing is the same.
Old 04-28-2010, 12:16 AM
New Member
no matter way you do its still the same.
____________________
Last edited by engineczar; 06-15-2010 at 06:04 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Cylinder Head Potpourri techinspector1 Engine 2 10-10-2010 05:06 AM
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
