Head gasket compatibility - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2010, 04:51 PM
Greg T's Avatar
www.krusinklassics.net
I've got a set of Trick Flow 195s for an SBC. Is it okay to use the .015" steel shim gasket with aluminum heads? I'm finding conflicting data on this.
Old 05-02-2010, 05:40 PM
automotive breath's Avatar
To avoid electrolysis caused by the dissimilar metals, use a rubber coated steal shim.
Old 05-02-2010, 06:37 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I believe Trick Flo leans towards the Fel-Pro gaskets - you might want to call TF and ask them what they recommend, and ask about any installation tips. I like to hear what the manufacturer recommends if I'm not sure. Some gaskets will leave indentations on alum heads if the gasket material is harder than the aluminum.
Old 05-02-2010, 06:52 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i'd also point out that you need to match your piston to deck clearance with your head gasket thickness to get your quench right. for optimull quench you should have a .040" clearance between the quench pad on the piston and the head. example if your piston @ TDC is .015" below the block deck (in the hole) then you should look for a gasket as close to .025" as possible (.015+.025=.040) i would not recomend running a .015" shim head gasket would be if you piston is .025" in the hole @ TDC, anything less than that, you should look for a thicker head gasket.
and call trick flow to see which head gaskets/ material they recomend. if you still have some paper work from them it should also be on that
Old 05-02-2010, 09:14 PM
Trick flow will recommend a composite gasket like Fel-Pro 1003
Old 05-02-2010, 09:18 PM
Greg T's Avatar
The slugs are .025 down the hole. D shaped dish and the heads are 62cc chambered. Thats why I would like to use the thin gasket. I will check with TF. Thanx!
IF they give me the OK on the rubber coated steel, does anyone have a recomendation/part number ?
Old 05-02-2010, 09:34 PM
ericnova72's Avatar
More for Less Racer
Fel-Pro #1094
Old 05-02-2010, 09:38 PM
Greg T's Avatar
Originally Posted by ericnova72
Fel-Pro #1094
Thanx much. After looking through Trick Flows site I am now more confused than ever. I am not sure what I have. The only numbers I can find on the heads are TFS-SBC-3, under the valve cover, and stamped into the front of the head I find
H 7038 1. I cannot find any references to these numbers anywhere. I got these heads on a rebuilt engine with nearly zero miles but the previous owner didn't have any documentation of they are. Anyone have any ideas?
Old 05-02-2010, 09:40 PM
Fel-Pro #1094
Yes thats the ones I use, rubber coated steel shim. It will get his piston to
head clearance where it needs to be. The only other option I know is to take it
apart and deck the block.
Old 05-02-2010, 10:08 PM
Another option would be to use a victor reinz gasket at 0.026" compressed
thickness for 0.051" piston to head. I don't have a part number but should be
available at a local parts store.
Old 05-02-2010, 10:13 PM
Greg T's Avatar
But now I need to know what the heads are so I know the chamber size. I THOUGHT I knew until I searched the Trick Flow site. Now I'm not sure.
Old 05-02-2010, 10:16 PM
Got a local shop that can cc them?
Old 05-02-2010, 10:19 PM
ericnova72's Avatar
More for Less Racer
If they are an older model you may have to call Trick Flow to find out, they redesign and update their heads every few years.
Old 05-02-2010, 10:31 PM
Greg T's Avatar
I sent them an email with the numbers because I see nothing about the casting or stamped numbers on their site. You would think they could number them and list them so that one could find some info.
Old 05-02-2010, 10:38 PM
How will you know they have never been milled, cc them is the only way to
know for sure what you have.
Cylinder Head Potpourri techinspector1 Engine 2 10-10-2010 05:06 AM
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
