Head gasket or crack ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 03:42 PM
outlaw17's Avatar
I checked out a buddies truck the other day (94 chev 5.7L) and it was making lots of bubbles in the rad , so I assumed he had a possible problem with a head gasket , we decided to tear it down and now that it is appart there is no 'obvious' problems with either head gasket , as well a no 'obviuos' problems with either head . Is there a common problem with these heads that I should be looking for , did they crack in a particular place ? The one thing that struck me as kind of wierd was when we took the valve covers off ,the rocker arms from #5 were a sort of shade of gold compared to every other one being dark black and dirty looking , the plug from that hole also had some build up on the ceramic portion of the electrode , is this some sort of indication to a problem ? Thanks .
Old 11-09-2008, 03:45 PM
King of my Man-cave.
While these heads do crack, it is far more likely a head gasket leak. Look on the head itself on the end cylinders where the fire ring on the gasket seals. It will be dark on the outer edge toward the end of the head.
tom
SBC 305 cracked head, blown gasket or? 35oldstruck Engine 6 11-02-2008 06:10 PM
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
Choosing correct Head Gasket - HELP! NovaHO Engine 4 05-30-2007 06:39 AM
Head Gasket or Piston Rings? 94dangerranger Engine 7 03-24-2007 01:33 PM
Blown Head Gasket???? hmmm Engine 4 11-10-2004 10:20 PM
