Head gasket direction - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2011, 03:09 PM
1986c10's Avatar
Hi ive got a 350 and dont know which way the head gasket is supposed to face because their is a shiny smooth side and a carbony rough side with the steel exposed. heres pics of both sides
side 1 smooth
side 2 rough
Thanks in advance
Old 07-07-2011, 03:44 PM
ericnova72's Avatar
More for Less Racer
In your case, with an SBC, it doesn't matter which way is up. They can go either way.
Old 07-07-2011, 03:45 PM
1986c10's Avatar
okay thanks alot, someone told me that once and i thought they were crazy! haha. Thanks again
Old 07-09-2011, 03:07 PM
fast68's Avatar
likes chevy trucks & boobies
yeah it dont matter,
as long as not covering up any coolant or oil holes,
and i always stick them shiny up or stamped numbers in it up though
but it dont matter really
use plumbers pipe thread dope on the bolt threads, it works good as a thread lube and as a non hardening sealer
i use it on all my head jobs always works great i been using it for over 17 years on all different engines 1960s to 2000s
have fun!
Old 07-09-2011, 10:50 PM
1986c10's Avatar
okay sweet then i should be set haha. Thanks alot
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
Head gasket help NOlowrider Engine 3 06-17-2010 08:03 PM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 12:10 PM
Will this head gasket be OK? 300Deluxe Engine 5 01-29-2008 10:46 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
