Head gasket help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 10:51 AM
NOlowrider's Avatar
US Navy-Retired
Head gasket help
On my current build, supercharged BBC 454 I chose to go with a copper head gasket for better sealing under boost. I am confused on the type of prep I should apply to the gasket before installation. A quick google search said "Hylomar" was a good sealer for head gaskets. Is this required for the copper gasket?
Street driven, weekend cruiser. 7lbs boost (max)
Thank you.
Steve
Old 06-17-2010, 04:54 PM
BOBCRMAN@aol.com's Avatar
Actually, on a street motor, with only 7 lbs. boost.. I wouldn't use copper gaskets. But, when I was racing BBC's. I just sealed copper gaskets with silver/chrome based cheap spray paint. Sometimes a little silicone gasket sealer around upper water crossover holes (if gasket was a good used one). Just spray a heavy coat of silver paint both sides. Let dry, then a second heavy coat of paint. Install wet. Torque heads and run..
On the street I like Victor/Reinz head gaskets..
Old 06-17-2010, 07:21 PM
NOlowrider's Avatar
US Navy-Retired
Thanks Bob for the reply.
I just figured out that I have the wrong set of gaskets anyway. I am going to s end them back to Summit and hopefully get a exchange. I ordered the set that requires the heads to be fitted for O rings. I waited almost three months for the wrong set of gaskets.
This whole build is starting to be a PITA. Wish I had never started, but I am so far in to it ($$$$$) I can't turn back. I only hope that when I get her completed that the blower will be worth the effort.
The blower snout is too short, had the switch to a short water pump, the lower blower pulley was wrong, alternator bracket doesn't fit, blower belt ideler pulley doesn't fit, ect. JUST A PITA
Thanks Bob.
Old 06-17-2010, 08:03 PM
I think most people are using the cometic layered gasket nowdays. I -personally don't like o-ring w/copper gaskets, they are hard as hell to seal up. JMPO
Thanks Bob.
Cylinder Head Potpourri techinspector1 Engine 2 10-10-2010 05:06 AM
Head gasket compatibility Greg T Engine 28 05-06-2010 11:50 AM
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
