Head gasket leak ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2009, 05:56 PM
truckboy61's Avatar
Head gasket leak ?
I have a rebuilt 454 with roughly 20 miles on it tops! and pulled valve covers off and discovered milky oil on rockers and underneath covers ! checked dip stick and oil looks OK ? any suggestions before pulling off intake and heads ?
Heads were never torqued after initial setting and header gaskets where just changed day .
Old 10-08-2009, 07:19 PM
DoubleVision's Avatar
This is common on a new build, it`s called condensation. The moisture rises to the top of the engine which creates the milky color in the valve covers, since it`s lighter it rises to the top of the engine. I don`t think you have anything to worry about. When you find water in the oil pan and it runs hot then you have a problem.
Old 10-08-2009, 08:51 PM
truckboy61's Avatar
Is there anyway to verify ? should I change the oil ? any suggestions...
Old 10-08-2009, 09:02 PM
Okay, if you insist. Having been through what your dealing with now several times I speak from experience. Put more miles on it and you`ll find the problem is gone.
Run a pressure check on the radiator for starts, if it checks out okay, there`s no problem. Number 2, run a compression check on all cylinders with the ignition disabled, all the plugs out, and the throttle set to wide open. If all cylinders are within 10% of each other, you don`t have a problem.
Does the engine have a miss? if it don`t you don`t have a issue. Usually when one has a blown head gasket you know it.
53 chevy truck smile a lot Engine 4 09-16-2009 06:01 AM
Head Gasket or Piston Rings? 94dangerranger Engine 7 03-24-2007 01:33 PM
Head gasket question? GMW Engine 7 04-06-2006 01:37 AM
Is this head gasket right? Stroker56 Engine 6 01-05-2006 09:26 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
