Head Gasket Question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2008, 06:11 PM
Hello Guys one question here.
I have a 350 Chevy, std deck block (9.025") with dome pistons (8cc) can i use .015" head gasket with it or would the piston hit the head (70cc-chambers) ?
Best Regards
Old 08-31-2008, 06:58 PM
Jmark's Avatar
It's a crap shoot with that thin of a head gasket and domed pistons. You really need to use some putty and check a few for clearance.
Old 08-31-2008, 07:24 PM
kleen56's Avatar
Anytime you use dome piston you increase the odds of lack of clearance. Like JMark mentioned, I'd do a measurement and make sure your timing marks on the timing chain are right on, otherwise, for sure you'll hear some sounds coming from the motor.
Old 09-01-2008, 09:59 PM
You also need to make sure your deck surfaces are flat enough to use a shim gasket.
Old 09-02-2008, 09:33 AM
If this isn't a race engine, where every CC has to be accounted for, I wouldn't bother. Too risky for too little gain.
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
Choosing correct Head Gasket - HELP! NovaHO Engine 3 05-30-2007 06:39 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
