Head Gasket Question - Imperfection
For my 327 build I picked up a set of 416 heads that are in excellent condition, and weren't used very long on a 350 before they replaced by Dart heads. They have new bronze valve guides and the valve seats are excellent. The head gasket surfaces looks excellent with one exception. On one of the heads, there is a very small imperfection that is directly on the mark left by the previous head gasket on the circumference of one of the bores. It is on the outside, not between clyinders. I can't tell if it was there when the head was installed, or if it happened after it was removed, but there is no evidence of leakage on the head surface. It is about 1/8" wide x 5/32" long and is two or three little depressions, kind of like rows (low spots between the rows). The low spots can't be more than .002" deep, maybe less. I sprayed some red primer on the mark and scraped it off with a razor blade and barely any primer was left visible.
So my question is should I be concerned about this causing a sealing problem? I don't really want to get them surfaced because I am already pushing the compression with these 58cc heads. (Will be about 10.4:1) Should I use Permatex Copper spray on the gasket? I know this sounds ghetto, but what about a little JB Weld to fill it scraped off by a razor blade before it sets? The JB Weld is rated for 500 degrees, the same as the Permatex Copper spray and it will be directly under the seal on the head gasket, not inside the combustion chamber. Any specific gasket recomendations would also be appreciated. Thanks a lot.
