Is this head gasket useable - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2009, 08:55 AM
GMR GMR is offline
New ROL sbc head gasket with slight damage to the orange bead seal. Is this gasket useable? Motor is 9.8 static compression.
Old 07-01-2009, 09:56 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
It's probably Okay but why take a chance.
Rich
Wiki Edits: 31
that gap will create a void where it could leak... looks like a manufactures defect
Old 07-01-2009, 11:57 AM
DoubleVision's Avatar
I would use a very small bead about the same size as present of non hardening sealer and let it rip. You could also likely use RVT without a problem.
Old 07-01-2009, 07:44 PM
GMR GMR is offline
thanks all
Head Gasket 101 camaro freak Engine 9 08-06-2007 09:39 AM
Choosing correct Head Gasket - HELP! NovaHO Engine 3 05-30-2007 06:39 AM
buy a used engine vs. replace head gasket? andrewpruitt Engine 8 03-21-2005 05:52 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
