Head gaskets. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2007, 02:46 PM
Head gaskets.
I need to know what are the best head gaskets for a 350 SBC. engine? I've had two sets go bad in a little over one year. Thanks for any assistance.
Old 04-02-2007, 02:53 PM
King of my Man-cave.
I would worry less about the head gaskets them selves and try to figure out why they are failing to start with. Are the heads straight? Are they being properly torqued? Are the deck surfaces properly cleaned? What is the application?
Etc.,
tom
Old 04-02-2007, 03:06 PM
rmcjunkin
I'ts a stock 350 in a 1990 1/2 t0n PU. I'ts blowing water out of the overflow reservoir.
Old 04-02-2007, 06:28 PM
BOBCRMAN@aol.com's Avatar
Like Tom said.. Why are they failing in the first place? '90 heads come from the factory with terrible surfaces, plus they like to warp up out on the ends.
Were these things checked for Warp?
I was once told by a gasket designer that he wished all engines were as easy to seal as a Chevy. With five head bolts around every cylinder, a piece of cardboard could seal the things up.
Old 04-03-2007, 08:04 AM
head gaskets
Thanks to both of you.
I checked the heads with the best edge I had (a carpenders level). I'll pull them again next week and take them to a machine shop.
Once again Thank you.
R. Mcjunkin
I cannot get my head gaskets to seal! hlweyl Engine 14 06-28-2004 03:26 PM
Head gaskets??? chevyelc81 Engine 2 06-01-2004 08:06 PM
Head Gaskets twoteam Engine 1 03-17-2003 10:50 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 09:36 AM
Head gaskets onehotchev Engine 1 03-08-2003 03:09 PM
