Head Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 06:38 PM
J.D J.D is offline
Head Gaskets
I have recently purchased my first set of aluminum heads for my street car, I will be running about 11.5:1 compression. I was told I had to run a special set of gaskets. Do I really have to have a special set or can I get buy with regular head gaskets like the some rubber over metal or somthing.
Old 07-14-2008, 07:28 PM
You need to use the correct gaskets to prevent brinneling the head.Fel-Pro 1034 comes to mind someone correct me if my memory is wrong.
Old 07-15-2008, 02:08 PM
J.D J.D is offline
gaskets
Do they make those gaskets in a .o6o thickness?
Old 07-15-2008, 05:34 PM
1010 Felpro is just for aluminum heads.
Old 07-15-2008, 05:40 PM
J.D J.D is offline
dgbdsz
The 1034's .042 thick,1010 are.031 thick. I need .060 to drop some compression.
Old 07-15-2008, 07:43 PM
May have to go with a set of Cometics or a 1044 which is .051 thick and the Felpro 1036 is for a 4.250 and is a thick gasket I believe.
Head Gaskets For Bbc - Which To Use leejoy Engine 4 11-01-2007 06:33 PM
Weeping Head Gaskets jleeheat Engine 15 10-20-2007 12:04 PM
I cannot get my head gaskets to seal! hlweyl Engine 14 06-28-2004 03:26 PM
Head gaskets??? chevyelc81 Engine 2 06-01-2004 08:06 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 09:36 AM
