Head gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 09:55 AM
Head gaskets
Hi,
Just about to fit my new cylinder heads to my 350sbc,I have bought the gaskets for a 400sbc which is 0.024 bigger bore size will that give me any problems? The thickness is the same!
Please advise if you can,thankyou
Old 08-06-2012, 12:17 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: bwaahhaahahaaahhaa
It shouldn't be a big deal. Most aftermarket SBC350 gaskets are 4.125" in diameter (on a 4.000" bore). This does slightly reduce the compression ratio as there is dead space between the head and block, but most people ignore it. Just pay attention to deck clearance and gasket thickness to keep your quench good (.040-.050" total).
The bigger problem is using a gasket where the diameter is smaller (like when you are +.060" and use a std gasket), the extra material dangling in the cylinder will get hot and cause pre-ignition.
Old 08-06-2012, 01:20 PM
I was thinking the same, 0.024 thou isn`t a lot really, works out to 0.3mm around the bore! Always nice to have a second opinion though!
2.5/3.0 Head Gaskets crussell85 Engine 2 03-27-2012 04:56 AM
Which Head Gaskets? 65malibuSS Engine 4 08-18-2010 02:53 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
What head gaskets do I need Bryce Engine 9 03-01-2005 01:45 AM
Head gaskets onehotchev Engine 1 03-08-2003 03:09 PM
