Head gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2004, 11:11 AM
'67 barracuda's Avatar
Head gaskets
i need to know what kind of head gaskets my 273 commando needs or if they just go by c.i.
Old 03-19-2004, 11:22 AM
poncho62's Avatar
Wiki Edits: 5
You can get steel gaskets or fibre gaskets. Suggest the fibre gaskets on a used motor. If the heads are warped slightly they will take up the difference, plus they seal better. You get slightly higher compression with the steel gaskets.
Old 03-22-2004, 09:21 AM
SAE Member; ASE Master Cert
Go to your local NAPA or CarQuest store and ask for Victor-Reinz #3536VC. These are composite gaskets and will work well on your engine. If you need the full head set with intake, valve cover gaskets, etc., the part number is HS3536A.
