which head gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2004, 10:45 AM
69 Ragtop's Avatar
which head gaskets
I'm looking for the correct head gaskets (part number if possible), for my 355 chevy short block. I will be using vortec heads.
Thanks, Brian
Old 05-05-2004, 11:10 AM
SAE Member; ASE Master Cert
Brian,
Welcome to the site! Vortec heads don't require special head gaskets, so any good quality aftermarket gasket will work. Victor-Reinz #1178VC is a good choice and can be found at most auto parts stores, including NAPA and CarQuest. Fel-Pro and Corteco also have quality head gaskets.
Old 05-05-2004, 12:59 PM
King of my Man-cave.
Make sure the heads have been resurfaced. The Vortec and TBI heads have a crappy surface finish and they are rarely straight to start with. I personally would recommend the Fel-Pro 501SD. It's the new HD Chevy SB gasket. It has thicker armor and is even better thatn the 7733PT2, the standard stock replacement gasket. I personally don't care for Victor head gaskets.
Old 05-05-2004, 01:10 PM
NorthStar's Avatar
GM makes a good gasket.
10105117
head gasket
Old 05-06-2004, 06:34 AM
GM gaskets are always a good choice, however you must remember that GM gaskets, including head gaskets, are manufactured by Victor-Reinz and Fel-Pro primarily. Corteco, Rol and some small gasket companies also supply gaskets to them. Same can be said about Ford, Chrysler, Toyota, Honda, Mercedes, Caterpillar, Mack, etc., etc.
