Head Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2005, 11:43 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Head Gaskets
I've asked this question around a month ago asking what people were using for head gaskets for a 350 with iron heads and got good results. Now I'm forced to get a new set of heads and I'm gonna get aluminum heads so I guess the Fel Pro 1003 heads gaskets might not be the right ones now.
What is a good gasket to mate aluminum heads on an iron block?
10.5 compression
64cc heads
Thank you
Old 10-09-2005, 11:52 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I use the regular blue felpro gaskets. I put Dynatex Hi-Tack Gasket Spray on them first.
Old 10-09-2005, 12:03 PM
The Big Money
So the Fel Pro 1003 are good for both iron and aluminum heads?
Old 10-09-2005, 12:23 PM
bracketeer's Avatar
489 Lemans
worked in every engine I built. my only concern with alum heads is a good quality alum friendly anti-freeze.
Old 10-09-2005, 12:42 PM
lluciano77's Avatar
Use the Felpro head gaskets with the recised cooling passage. They have you drill a 7/16" hole in the deck. Then the gasket restricts the outer passages closest to the exhaust valves. This help keep the block temp more even.
What head gaskets do I need Bryce Engine 9 03-01-2005 02:45 AM
? about copper head gasket's bowtieorbust Engine 21 08-15-2004 11:49 PM
I cannot get my head gaskets to seal! hlweyl Engine 14 06-28-2004 04:26 PM
Head Gaskets HotRodS10 Engine 4 08-13-2002 05:30 PM
400 SBC Head Gaskets MI2600 Engine 2 07-21-2002 02:41 PM
