Head identification and c.r. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 09:01 PM
Want to know what the chamber size of a chevy head, 14102193...As much as l looked up, l can't find the chamber sizes, l found the valve size. Any help would be appreciated thanks
Old 04-13-2013, 09:45 PM
eight90's Avatar
They are 64 cc give or take a cc. Others have cc'd theirs here and I cc'd mine as well, just to make sure.
The Following User Says Thank You to eight90 For This Useful Post:
fordss (04-13-2013)
Old 04-13-2013, 09:46 PM
Sorry guys, l found what the chambers size was. I don't know how to delete the post, but since it's still on; could l put a 268 high energy cam in it with these heads? Thanks
Old 04-14-2013, 12:52 AM
mikesnyhere's Avatar
I used a 270 adv duration with 9.1 to comp. ratio it worked really well on a ported 302 . I would hesitate to use it on anything less than 8.8 . what is recommended ? the 268 is a high energy Crane ? their recommended specs should tell you a recommended CR , and if new springs are needed . best to look at what the cam manufactures suggests .
Old 04-14-2013, 04:25 PM
DoubleVision's Avatar
You don't want to use 193 heads. These are TBI "Swirl Port" heads. They give a engine real good low end torque and fuel economy, but due to the swirl port, they run out of breath at 3000 RPM.
Name:	SBC Swirl Port Head.jpg
Old 04-14-2013, 09:24 PM
what will my compression ratio be
1991 chevy 350 with stock pistons I believe dish pistons going to put procomp 58cc heads on. What would the compression ratio be.
Old 04-14-2013, 09:41 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Plug in the numbers:
RSR Static Compression Ratio Calculator
Old 04-14-2013, 10:31 PM
Sorry I'm not that smart I have no idea how do that
Old 04-14-2013, 10:44 PM
Ok I was thinking of do procomp 58cc head 210 flow I just don't know what my compression ratio be. I do not know how to do calculator tool on the web. It is 1991 chevy 350 if some one could tell what it would be great
Old 04-15-2013, 12:38 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Just get the information the form asks for and it will calculate your c.r., if you have dish pistons, need to know the volume of the dish in cc's, how far the piston is down in the hole at TDC, typically .025", compressed gasket thickness, typically .041", etc.
We could guess at about 9.5:1, but...
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
fordss (04-15-2013)
Old 04-15-2013, 01:05 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your earlier post has been merged with this one.
Semper Fi
Old 04-15-2013, 01:36 PM
techinspector1's Avatar
Wiki Edits: 326
If we figure the dish at around 12cc's (trying to be real here), the static compression ratio using 58cc heads on a 350 would be 10.3:1.
The Following User Says Thank You to techinspector1 For This Useful Post:
fordss (04-15-2013)
Old 04-15-2013, 10:26 PM
What cam should I use With that ratio ? I want to try to use my stock torque converter.The heads will only do as high as 550 lift . My car is 3300 lbs. Any help would be great
Old 04-15-2013, 11:30 PM
Wiki Edits: 326
I'm getting some bad information from KB's site. Your SCR would be more like 9.55:1. I'm going to have to begin figuring this stuff myself instead of taking someone else's word for it.
Use a cam with intake duration somewhere between 205 and 220, with 212 as a middle ground.
Old 04-20-2013, 07:41 PM
El Rob's Avatar
Any one used the procomp heads yet. i have read a lot of good and bad. The bad seems to be small like valve covers not fitting right. I looked at them for some time at Skip White site.
Not trying to hijack you thread.
need some head identification help. inlovew/327's Engine 4 03-18-2010 07:40 PM
Head Identification American Muscle Hotrodding Basics 1 01-06-2009 09:32 AM
head identification quincysmith Engine 6 08-02-2007 09:49 PM
GM Head identification. Super Chevy Engine 1 09-18-2003 04:41 AM
GM Head Identification Help bigjoedo Engine 2 09-11-2002 10:39 AM
