Head and Intake Choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2011, 09:43 AM
I've decided to step up my performance a little bit and switch to a set of vortec heads and intake. Only problem is I'm not sure which ones to go for. I've got a 72 350, I've heard you have to have a specific style to fit on an older block. Is there any numbers I should be looking for or can anyone provided links? Any help is appreciated!
Old 05-20-2011, 10:03 AM
So far this is what I'm looking at. Will this work?
http://cgi.ebay.com/ebaymotors/GM-30...ltDomainQ5f210
http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories
Old 05-20-2011, 10:16 AM
Banned
The intake will work, the head listing is unclear as to what heads you would be getting.
Old 05-20-2011, 01:38 PM
It looks to me like it says they replace 882 heads, which if I'm not mistaken are what I have on there right now. Also, I've got stamped steel roller rockers, I'd imagine id be able to swap those over correct?
Old 05-20-2011, 01:47 PM
Banned
If they replace what you have then there is no sense on changing. And if you switch from non vortec heads to vortec heads you either need new rockers or need to modify them for guideplates. I would keep looking on those heads.
Old 05-20-2011, 03:25 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If I am not mistaken don't center bolt Vortec heads use a different shaped rocker vs. non-vortec to clear the valve cover fasteners? Regardless of guide plate.
Old 05-20-2011, 04:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Of the heads listed, you want the casting number 10239906. The other Vortec L31 5.7L head that will work is c/n 12558062.
Vortec heads require what are known as "self aligning" rocker arms. CLICK for some more info on Vortec heads and mods to them, etc.
Below are views of the cast-in identifiers for each head. Left is c/n 062, right is c/n 906.
Name:	062 VORTEC END ID 001.jpg
ID:	55463   Click image for larger version
Name:	906 VORTEC END ID.jpg
pontiac intake choice. AndersonRacing44 Engine 20 02-06-2011 12:42 PM
Cam & Head Choice Dino383 Engine 10 06-03-2010 07:21 PM
Head choice Mets63 Engine 12 03-23-2009 02:04 AM
Intake Manifold Choice? Please Help sb72elcamino350 Engine 3 06-04-2005 06:58 PM
Head Choice for Fod 302 ERP Engine 2 09-19-2004 11:26 PM
