The most likely cause is the connections (plug) at the switch are not tight, which can cause overheating. Poor connections = heat. As the heat increases the connection gets worse because the resistance at the connection increases.
I'm assuming that no aftermarket lights have been added to the car. This can cause excessive (beyond the switch design) heat at the switch. If the problem occurs after a time, say 10 minutes, the poor connection is the problem. Check the tabs on the plug and connector for discoloration. Also, the crimped connection on the one of the wires may be bad. Or, was never done correctly from the factory. Once these electrical connector are heated, they loose there spring and the problem gets worse. You may need to replace the plug. vicrod |
Doc here,
Here is the diagram for your light switch: ![]() If this is the 3 Rd switch, I'd check with the dealer first about recall notices.. First thing I'd do is get and replace that bad/Melted connector , the pins can be loose and vibrating, causing a Heating issue at the switch. Check your high/low switch for a possible bad contact on the low selector. (although I should think the High/low would go out first) Check ALL your lighting system grounds. look for an intermittent or less than dead short on the lighting circuit. Doc.
Aftermarket Solutions Electronic & Electrical Innovations |
| How does a dome light wire up | Ed ke6bnl | Electrical | 2 | 01-14-2006 07:37 PM |
| hazzard light switch | john kerr scotland | Electrical | 1 | 11-22-2005 12:43 PM |
| bad brake light switch on master cylinder? | flamedfordbronco | Electrical | 3 | 07-10-2005 05:34 AM |
| 72 camino light switch knob | Scuzzy | Interior | 3 | 03-21-2004 07:01 PM |
| Remote Shut Off Switch doesn't shut it off! | F-1Rodder | Electrical | 2 | 05-01-2003 04:01 PM |
