Head light upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2011, 04:16 PM
Head light upgrade
I want to upgrade the head lights on my 57 Chevy pickup , anyone have any suggestions ? Something reasonably priced and something that I won't need up the amps in my altenator for.
Thanks , Gene
Old 12-04-2011, 05:50 PM
poncho62's Avatar
Wiki Edits: 5
Years ago I put some Bosch halogens in my 55 Chevy....worked fine without upgrading wiring etc....I dont think that todays brighter lights take any more amperage than what you have in it now, maybe less
Ontario Rodders
Old 12-04-2011, 05:57 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Check out this site on making your lights brighter: http://www.danielsternlighting.com/t...ys/relays.html
Old 12-04-2011, 06:04 PM
headlight wiring
I believe that halogen lighting will require 16 awg wire as found in many north american cars. Of course you could easily upgrade using a relay located close to the headlights for super high intensity current hungry headlights.
Old 12-04-2011, 06:20 PM
kleen56's Avatar
I know I've always upgraded to the basic halogen headlights. Their bright and easy to install. I installed relays on my headlight wiring anyways, although is the lights are slightly brighter, I noticed a big difference on draw from my alternator using my voltmeter. Without the relays, my voltage dropped below 12Volts with the lights on. With relays, the voltage stayed around 13.2 volts.
Old 12-04-2011, 07:59 PM
bondo's Avatar
Ayuh,.. I've converted several rigs over the years, back when the headlights were either 5" or 7"...
The component lights are, like everything else, dependent on the components used...
Something like This , has leaded Crystal lens, 'n a myrid of choices of bulbs, from the normal 55w/ 60w, to 80w/ 100w blinding light...
The lens, the way their cut, is amazin', 'n really puts the available light where it's needed, Without blindin' the poor sucker comin' at ya on a windy 2 lane goat trail...
The low beam cut off, aka; top of the beam, can be held to waist high, for darn near forever...
Btw,... Never up-graded the wirin' on any of 'em, 'n never had any Issues...
Old 12-05-2011, 12:41 PM
ogre's Avatar
the 'Duracell Project'
57haldton: lmctruck.com sells a halogen upgrade to replace your existing t3 headlights.
i use them on my truck, they light up the ground very well (i just have never aimed them correctly).
lmctruck.com
Vortec head upgrade worth it? dave350v8 Engine 25 02-11-2011 06:13 AM
head upgrade for 468 big block Jason7504 Engine 22 05-08-2010 06:37 PM
Head upgrade for 1987 L98 TPI,What you think ? Calderone Engine 20 09-11-2009 12:14 AM
SBC head upgrade upstand2 Engine 7 09-04-2005 03:39 PM
HELP!!! Going to upgrade need some head and cam advice leemoses Engine 1 07-19-2004 06:40 PM
