Head lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2005, 01:03 PM
Head lights
I have just got a '96 Trans Am. Whenever i put the headlights down, the motor to lower them just seem to keep running for about ten seconds afterwards. Can NE1 help me out?
Old 06-06-2005, 05:24 PM
docvette's Avatar
Wiki Edits: 12
Door limit switch
Doc here,
Well, being upfront ... Never worked on a T/A with headlight doors before, But Have done so on Corvette..
Look to see if you have a "Down Limit Switch" on the door (s) It should be a small micro switch located on or near the door linkages, you'll probably have to look real close with a flashlight and inspection mirrors if it's there..
If you find the switch, to verify it's the down limit, get a screwdriver and with the doors open, shut off the lights and trip the switch before they close..Travel should stop.
If and When you find this, adjust the switch or linkage to trip just as the door is level with the rest of the front clip..That should do it.
Some just use a gear drive for so many rotations = Closed...If yours is this way then you'll need a linkage adjustment for the doors..
Possibly Someone who has had actual experience with the T/A headlight doors can add more...
Doc
So, who has experience with flip up head lights? Vegaburnout Electrical 2 04-14-2005 06:26 PM
Head lights schematic 39chevy Electrical 3 12-29-2004 05:46 PM
relays on head lights 49dream Electrical 4 11-04-2004 09:36 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
frenching head lights rot_n_rollzombie56 Body - Exterior 4 02-25-2003 04:31 PM
