head liner 68 camaro, need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 04:31 PM
I have a 68 camaro that needs a headliner installed. I need to get directions for the installation. Does anyone know where I can find these?
Thanks
Old 02-02-2007, 07:53 PM
BOBCRMAN@aol.com's Avatar
Instructions.. Pull the windshield and rear window and take car to a good trim shop... As stated before headliners are not for amateurs. Nothing looks worse than a botched headliner job,, Except a bad convert top install.
Old 02-02-2007, 07:58 PM
poncho62's Avatar
Wiki Edits: 5
Is it the type with the top bows?
If you can buy a presewn kit, its not too hard to do. I sewed my own 55 Chevy one and got it a bit out of line and like Bob says, it didnt look right.
I did do my own convertible top on my Pontiac and it turned out great.
Ontario Rodders
Old 02-03-2007, 08:20 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Bob's right. Take the car to a trim shop. If you screw it up the first time, you'll end up paying more than if you took it to a trim shop in the first place. Good luck.
Old 02-03-2007, 01:28 PM
It is the presewn type with the bows. What would be considered a good price for the installation if I already have the headliner. Thanks for the help fellows.
Old 02-03-2007, 03:39 PM
Wiki Edits: 22
You can expect to pay about $300 or more, depending on what condition the car is in. Is the old headliner out of the car? Look at the headliner pictures of the '49 Packard in my project journal. That headliner was made from scratch. With the fabric and listings and installation it ended up being $700, but the headliner is wool broadcloth which costs a lot more than felt or vinyl.
Old 02-03-2007, 04:17 PM
scully, if camero headliners are as cheap as mustang headliners ($30) you can buy 2, use one for practice and see if you have the knack before you shell out $$$
there are web articles that cover all steps...
here's my trick to make it come out super (no sags, no winkles) at a stationary store (Staples etc) buy a box of the steel "binder clips" (triangle shape, 1" with the wire "to open" handles)......they work excellent to clamp and hold the cover over the sill or roof lip as you stretch and clamp inch by inch pulling out the wrinkles or sags.......they do grab really hard....you can stretch h**** out of the cover..... what you just stretched and clamped won't move
use them to clamp and hold all 4 sides as a trial fit with no glue to be sure all is straight.....
Old 02-15-2007, 12:33 AM
1969 Camaro owner
First gen Camaros all use bows to keep the middle in shape and all you need to do is worry about properly stretching the vinyl over the lip where you push on the plastic "U" trim. The windshield pillar corners are kept taut by pulling the material tight as you bolt on your sunvisors, pillars go over the edge of the vinyl. All four sides are done this way and the final peices to do which are the trickiest are the sail panel areas. Those span a good distance and the sail panels go into the side over top of the roof material. You definately do not need to goto an upholsterer or take out the windows though for front and back its a little tight with the tool they usual ship it with.
572 in 68 Camaro smac68 Engine 9 05-07-2006 08:07 AM
572 in 68 Camaro smac68 Transmission - Rearend 1 05-05-2006 08:44 AM
Installing 9" Ford in 68' Camaro 1bad68camaro Transmission - Rearend 4 04-17-2006 11:00 AM
'68 Camaro front brake/disc power conversion problems nathanlburns Suspension - Brakes - Steering 9 05-14-2004 08:22 AM
Head Liner for 79 camaro with t tops the ernster Interior 2 04-08-2003 06:21 AM
