Head pick help with SRP #141636 piston Help!!
Hello agian
my short block is all done and drop off these heads that I have to get re-done
3964291 old LS6 454 rect port heads. Come to find out they has been port work in the chambers to the extent of 111cc up to 114cc where the factory says these heads should be 108.9cc's which is what I designed my cam pick, piston pick etc... Each cyl on each head is a little different. Got taken to the cleaners on these boat anchors. So much for honest joe's. Anyway I need a set of heads that will work with the already put together short block piston #141636, 14cc dome for these closed chamber 291 heads. I was looking at the Edelbrock #60499 with 100cc chambers semi-open. Will these work with the SRP-141636 piston? OR??? any thoughts. Didn't really want aluminum, but
these 60499 are. Shop is throwing the 291's back together with old stuff to cc all 8 chambers and if they are all the same or close on each head say 114 on one hea and 11 on the other could I just have them milled to 108???
Anhy help or thoughts would be great man
thanks
