Do a search on head porting on the web and you will get all kinds of info, what they don't tell you are some of the secrets that have been learned from experience, here are a few I know.
-Buy carbide cutters and save the cartridge rolls until the very last finishing operation, the work goes much faster.
-You will need a good die grinder and a full face shield, wear safety glasses under the shield too. Those cast iron shards are nasty. Ear plugs and muffs will be mandatory or you will go nuts or deaf after 12 hrs if you are using copmpressed air.
-Buy a couple 1/4" drum cutters and a 1/2" drum cutter as well as a couple ball cutters of different dia. A tulip shape cutter and a tree shape is handy too. Buy all of them in double cut configuration, it takes less pressure to cut.
-Use aluminum duct tape to protect the valve seats, use a few layers for extra protection. You can also use it to scribe your lines onto so you can grind to them when laying out the ports.
-Remember whatever you do to one chamber or port you have to do to the others, if you spend 10 hours on one port and chamber you are going to be doing this for a while. Don't ask how I found this one out, two weeks of summer holidays are gone from my life because I was ambitious-at 16 hours a day! You can't see the ports and chambers from outside the engine either!
-Don't take out too much, stay to the short side radius and just blend the nasty obstructions and match the ports.
-Don't touch the quench part of the chamber on wedge chamber heads, just rough polish the chamber and then leave it alone.
-Use a little brush to remove shavings, compressed air just gets it in your hair, eyes, clothes, underwear, ears, shoes.........
-You can use spray dye to match your intake ports just test assemble the engine (use your gaskets)and use a vacuum on the intake port from the piston side and spray into the intake manifold, it will mark your ports just dandy.
-Blend around the valve stem protusion to streamline it in the port and use a valve with the head cut off to protect the guide interior. Do not remove the protusion!, this is your valve support!
-Stick old spark plugs in the plug holes to protect the threads.
-The area just below the valve head and the short side radius are where all the gains are to be found, just rough polish the outside radius's.
-Most cylinder heads can accomodate a 1/16" removal inside the ports and that's all!!!!!
-80 grit is just right for roughness of finish.
-Do your valve job after the porting in case you slip and hit the seats-you will!
Let us know how you make out when your done, some pics would be great!
[ April 30, 2002: Message edited by: 4 Jaw Chuck ]</p>
Outlawed tunes from outlawed pipes
